Stability control disable
Lurch.sho
Orlando
Do you not have the Driver Assistance Package with the LDW or Auto Park or are you going to eliminate those switches?
I'm curious about this as well, I have auto park but no LDW so I have one blank button there. Is it possible to wire up the switch I already have so the auto park button (Which I haven't used once) functions as a traction/stability control button? or would I have to get one of the new switches from rock auto?
Ta2dResqr
Central Ohio
you can order the switch with just the TC on one side and nothing on the other. There was 4 options.
see pictures here https://www.rockauto.com/en/catalog...trument+cluster+voltage+regulator+switch,4528
I understand that part. However, there is only one location for the button. If you have Auto Park or LDW, you cannot get a combination that has the TCS button. You either have to 1) not have LDW or Auto Park 2) hide the buttons for those options in the console and mount the TCS in the OEM location or 3) mount the TCS or other buttons in a custom spot. I was curious what your situation is.
Personally, I have both Auto Park and LDW. I would like to add the TCS button. If you are in the same situation, I was curious what your solution is.
76FoMoCo
Nampa, ID
Mine are blank so easy for me.
76FoMoCo
Nampa, ID
Trim piece came off easy and when I got it out found the wiring was not there. :(
Florida
That surprised me too.
Had a similar experience swapping seats in a fusion from cloth to heated leather. Completely different harnesses, 2 year difference in car, same trim level, now the airbag lights on and the heated seats don't work. Not even a bulkhead up stream, all one continuous interior harness. Gone are the days of infinite interchangeability, my foxbody has parts from half the ford/lincoln line up across 3 decades.
2013SHOpp
seattle
I have a 13 pp. It came with 20 inch rims and a traction button. But I've never got it to go into sport mode like the manual says it should. I can hold the button down for 5 seconds and advanced track off pops up on the dash and then put the gear selector into sport. The manual says it should come up sport mode or so.ething but mine never been able to do it
kryptto
South East, Florida
Mine in s nothing on dash either
