"Squishing" noise from under car, NOT tires
Isaac Shea
Honolulu, Hawaii
Aloha,
I'm gonna submit this video link in the hope someone can identify what this sound is. A little background: That intermittent "squishing" or "tires on wet glass" noise only occurs at low speed, only when I turn, and only when the car is hot. It doesn't make this sound when cold. It's not the tires because I changed all 4 recently and it hasn't stopped. Ford doesn't know what it is, and the last two multi-point inspections revealed nothing under the car.
Any help or guidance is much appreciated.
https://photos.app.goo.gl/eqQkayWhMYZnEBkX8
Mahalo, Isaac
Bluezone
Ont, Canada
I couldn't get the video to play. From what you're describing I suspect either an alignment or a worn bushing problem.
toms89
Difficult for me to hear it in the video. A parking garage tends to amplify any noise the car is making because you hear it reflecting off the surfaces. My brakes made some noise that I would only hear in a parking garage till I finally replaced pads and rotors. Did this only during turns interesting enough and while not actually on the brake pedal so that may be one possibility to consider.
crystizel
