strings1732
RMTE-TRBO-SHO
So, a few months ago, I spun another bearing. The motor siezed. I figured it had siezed because I drove it home with the spun bearing(about a 1/2 mile to 3/4 of a mile distance). So, I finally got into the motor and I figured out what had happened. There are 2 studs that hold the oil pump pickup tube to the oil pump. The 2 nuts that hold it up came off. They backed out from vibration or something. The funniest thing about this is that I never touched these nuts. This means that ford, did not tighten these to the proper specification, or that the proper specification was not enough. So it may be a good idea, to loosen the oil pan and put some loc-tite on these nuts so this doesn't happen to any one else.
Oh and just to let you know, I fully spun 3 rod bearings, possibly more had started. I fully spun one main bearing and 2 more mains had started to spin for sure. I even started to spin a thrust bearing. It has a slight scratch on one side of it, from where the main bearing spun and scratched it. I hope that this never happens to any of you.
I know driving on it didn't help, but that's ok. This has given me an excuse to take the car where I want it to be. The motor is going to the machine shop tomorrow(hopefully). It is getting everything re-done, including a 50% overbalance, new-ish rods/pistons/crank, a line bore, resizing of the rods and possibly a flash grind as well, new rings and all new bearings. I just have to find some thrust bearings now...(good luck on that one, I know). When I'm done, the motor will be new-ish and painted, it will be turboed, it'll have new exhaust, be A/C delete and hopefully lose quite a bit of weight from other things as well. When I'm done, this will be a new car for me.
