springs and struts
SHOred
North Carolina
I have bought a set of the B&G lowering spring (1-1/2" front) for my 93 3.2 mtx. I am going to replace the struts also. I am leaning towards the Monroe Sensa-struts. So if I go with them what else will I need to get so it can be aligned once everything is changed? I have read several of the articles and I don't fell real good with the list I have found. Can someone or maybe several come up with a really good list of everything I will need? All help will be appreciated.
Shored
zblackbeast
SHOtarded
Omaha, NE
If you've got the springs and struts picked out, all you really need are the strut mounts and strut bearings for the fronts.. depending on how many miles/the shape of your sho/other repairs done yoj might as well spend a couple hundred more bux and just replace all your bushings as well. (Front and rear strut rod, sway bar bushing and endlinks, ball joints and or tie rods...just replace eveything so you wont have to tear it all back a part in the future... if your doing it yourself I think all the above cost me around 500 dollars or so.
-DVP-
NaNaaNaNAAAA!!!
0 .· ` ' / ·. Full Retard
I would Gen 3 sf swap it before replaced all the bushings up front. Can't speak for B&Gs but I like my Sensatracs.
Plus with the convention I bet you can get a SF brought to NC next month.
crystizel
