Sport mode
Sport160
Texas
Damn they keep changing things :)
What about on a 15 SHO with PP does that have the ESC somewhere? I thought one of the "perceived" PP advantages was that it a had 3 modes of ESC, did they stop that as nobody used it?
Always seemed odd to me, the SHO is hardly 1st choice of a track car, at least for a road course, so never really thought many people would be using the variable ESC modes
OmaHahn
Omaha
Almost right, Sport160, however, if you have adaptive cruise control on a 15, the buttons under the little lift up flap are: rear blind, auto park, and lane keeping system on/off. No esc button, it must've escaped......
You don't have the ECS button because you don't have the "Performance Package," on your car.
OmaHahn
Omaha
Yes, with PP it's in same spot as usual.
I turned 13.78 at the track just leaving it in drive. Sport mode is better for navigating heavy traffic, but uses more gas.
Cool, I turned 13.79 just leaving it in Drive as well. Never even bothered putting the trans in S ...
steelgiant5
I turned a 13.503 in S... 13' non pp no tune.. I use sport mode when not on highway, it downshifts when coming down hills when you hit the brake also
Sent from my iPhone
D.T.R
So i think the original post was about the difference between D and S on the gearshift selector and how the car feels way more responsive in S, not about the different mode on the ESC
And no on the 13 and later cars, the ESC button is under the little lift up flap in front of the gear selector, where the button for the automatic rear blind is and the auto parallel park button is (if you have that option)
Thank you for the info. I've been looking for this button (got the car last night, so it is all new to me), but no one has mentioned where it is lol. Thanks again.
guspech750
I love driving around in Sport mode. It is just simply more enjoyable to drive around in. I enjoy the sounds of the motor staying in the upper RPM range with out a single f given about gas milage. ;)
Sent from The White House on taxpayers dimes.
DTR + 4.10's + Eaton swap = Wreeeeeeeeeeeeeeedom
D.T.R
^^ That button must be a PP only deal... my car doesn't have that, instead it has the self parallel parking button. I found the traction control through the settings in the cluster.
UtesFanRy
Utah
On 13+ models the ESC button is here if you have the Performance Package. If it isn't equipped with the PP, you won't find an ESC button here. This button is how the Traction Control / Stability Control nannies are put in "Sport" mode or completely disabled.
SHO311
2013 PP Roush intake SCT tune.
Gilbert
I LOVE Sport mode here in AZ. makes it growl better, when I get on the freeway I use D. If you really want to make your passenger scream leave in in park push the traction button 2 times...true sport mode is right! nothing like drifting at 85 ! :)
I drag raced half my adult life, so not getting PP would've been unimaginable. But now that I've been driving with the Driver Assist Package for a few months, I can't imagine not having it.
OmaHahn
Omaha
Well....you can't drift that well when just pushing the Traction Control button twice - all this does is reduce Traction Control and Electronic Stability. To drift you want to shut off the entire system - do this by pushing and holding the ECS (traction button) for 5 seconds and then all safety measures are off!!! Then your passengers be like: :omgsho: and like: :eeeeeek:
SHO311
Gilbert
Yea thats the mode lol I get mixed up some times ..when it's in "track" mode. I just need my new parts ! It's like snail mail when it's for my car takes forever ! Getting PTU flushed tomorrow morning I'm going to find this stupid shutter feeling at really low rpm 3rd gear ! Never give up. after I find out what it was I'll repost.
jtmartin8819
Indiana
There's actually 3 Sport settings in case you were wondering. If you tap the ESC button just once all it does is turn off Traction Control. If you hit the button twice the dash with say "Sport Mode," and all this does is limit the amount Traction Control kicks in and limits the amount of Electronic Stability. But if you press and hold the ESC button for 5 seconds it shuts off everything - true Sport Mode!! :)
Does it do this on the 2016's as well?
In some cars yes. My 13 PP does not go into the actual sport mode by pushing the ESC button twice. However, when I put the shifter in S my car behaves completely different just as stated above.
jtmartin8819
Indiana
My 2016 doesn't have an ESC button, but when in sport mode it does keep RPM's higher and seems to be a little more responsive
Only PP cars have the ESC button. You can turn off traction in the menu on the left side of the cluster of a non PP car. You just cannot completely turn the system off.
jtmartin8819
Indiana
Mine must not be a PP...only has the traction control in the driver assist menu like you said.
If you go on my big thread, it will help you determine if you have a PP car or not. I have seen one case (only one) of a verified PP car that did not have the ESC button. It was actually a screw up at Ford. He was able to procure the button and assembly, install it, and his car worked perfectly.
