Speedometer fluctuates
SHOisfun
North Carolina
I noticed that occasionally my speedometer, especially around 80 mph, bobs up and down. Not all the time but sometimes. What's happening? Thanks
zoomlater
Seattle, WA
When was the last time you lubed the cable
Does this only happen at 80 mph
most likely cause is a cable that is binding and needs lubed/replaced.
Off Road SHO
Moderator
No, just unscrew it from back of gage cluster, get some speedometer cable spray **** with the thin red nozzle. Insert the nozzle into the cable jacket, right up against the twisted wire core. Clamp your fingers around everything to kind of make a seal so that when you hit the spray, it sort of forces the **** down into the housing. It's messy and you waste a lot so wrap a rag around your hand holding the cable to catch all of the mess.
Tom
AKghandi
could this also cause a speedo to randomly go from around 65 to around 100 for a moment? mine does this occasionally. freaked me out first time as i was moving at a pretty good speed and looked down to see my speedo say i was doing 110.. then it went back to 70 whew.
Off Road SHO
Moderator
Ok, I'm not familiar with how the speedometer gets its info on those. If it's mechanical just do as I mentioned above with the ****.
Tom
