DARTHSHO
car is almost at 60k miles so I’m going change the spark plugs was wondering what kind i should use. I heard the sp542 are better over the stock ones. I want to be able to run e85 in the future also
Thanks, SM105K. As soon as they arrive, I'll gap them at the low end and install. It's been years since I actually changed the plugs in any vehicle, so it should be an adventure!.028 to .030
Thanks, #76FoMoCo. I already have the anti-seize and dielectric compounds for installing the new ones.It helps if you spin them as you lift
Don't break those ******* red clips!
Mouser or Digikey usually have such parts in stock.
The red clip isn't necessary for use, it's just the "I'm critical to engine performance, are you sure you want to remove me?" identifier.
