sound from engine
goalieman59
Learning Slowly
OFallon, IL
it looks like the tensioner pully is locked up, at least if that is the pulley that is closest the alternator.
goalieman59
Learning Slowly
OFallon, IL
I will try and pull the belt, this weekend. When I need to put the belt back on how do I tighten it correctly.
goalieman59
Learning Slowly
OFallon, IL
Ok so took the belt off, and found the pulleys are making noise, and the waterpump is making a noise also. But what suck I think my crankshaft seal is leaking, cause I found a little oil above the pulley.
