Trus, but it's trivial to add the 36-1 wheel to an engine, and drop our crank sensor. At it's core, the SHO engine is conceptually no different than any other DOHC V6, there is no reason why Megasquirt would not be able to run it.
so you also need to take off the crank sensor replace it with one of theres (for how much money?) and replace the crank sensor wheel?
does this replacement one line up or do you need to make your own ?
i have a question regarding the sequential fuel. without the Sequencer, would it run like regular EFI firing 3 of the injectors at a time or what? I dont know a whole lot about the electrical/tuning aspect of these motors yet.
Megasquirt
what kinda name is that?!
This is awesome! I haven't run mine with MS yet, but it's cool to see someone who has. Once you get the tune dialed in (I assume you have all the necessary goodies, like a wide band o2 sensor, etc?) I'd be very interested at looking over your msq files.![]()
actually at the time being since im just playing around with it on a parts car im not gonna use wbo2 for it... when i go to put it on my 92 im gonna go with WB.
hopefully i can get a video here next weekend sometime ill try and go threw some of the process i went threw and stuff i setup to get it up and running for a SHO..
i think in the near future there will be the DIYPNP for SHOs which will be plug and play no splicing wires etc. fully sequential fuel injection and some other goodies...
i recommend checking out their website and seeing whats out and such..
I doubt there will ever be a DIYPNP version for the SHO, just not enough people interested to justify them making it. However, even if there was, you'd still need a custom harness to really use the MS, the stock harness just doesn't have everything wired for fully sequential (ignition, for instance).
Not to be a debbie downer, but the adage "if it ain't broke, don't fix it" comes to mind. Rewiring your injector harness, swapping to COP, just to run an unsupported computer that requires more modification of the wiring harness. Granted, if it can make reliable power that is head and shoulders above the Tweecer, I might consider it. But right now, what would one have to gain? That is not to say, do not do it. But like with the Tweecer, I will take the lazy guys approach and let other people be the groundbreakers, and then reap benefits from their hard work.![]()
