Rubix
- Joined
- Jan 12, 2005
- Messages
- 1,329
- Reaction score
- 858
Signs and smells pointing to head gasket. Not sure how this could've happened, the car hasn't overheated. This car has always run hot, especially in the summer. I've been DDing it to work lately, it's been performing fine - loving the cold morning air, and in these recent cold weeks it hasn't gotten too hot at all.
So anyway, started the car up last night, seemed unusually low on power on startup. Slow to crank as if the starter was going out (this would be literally the 6th starter in 2 years). I knew the alternator and battery were good after having recent and resolved issues. Car didn't feel right once running. Sounded off, lower tone, and slightly muffled; was also shaking a little bit as if the mounts were bad. I hop out, a bit of smoke in the exhaust. I turned it off and drove the other car.
Today kevinspann is at the house and we start it up. Same deal, and now that it's daylight, it's confirmed that yea we got some smoke! It wasn't bad at first but was noticeable. After a minute or two running it gets thicker. We turned the car off and realized water was dripping out of the mufflers. No change in coolant or oil levels. No coolant in the oil on the dipstick (yet). No oil in the coolant (yet). Pulled front 3 spark plugs off, no green inside. Will check the rear 3 tomorrow and probably drain the coolant. Not tearing into it until we do a compression test. I'm hoping this is savable since it doesn't seem to detrimental (yet).
Just throwing this out there:
Since 2009, this car has had the thermostat replaced, radiator flushed, water pump replaced, and it's on it's 2nd radiator cap. I know how to burp the cooling system. I've always been mindful of these things to prevent a BHG since this car has always run unusually hot.
Anyway, I'm awake and bored, and while slightly embarrassed about the situation figured I'd post. Any suggestions here? I keep reading things like change the radiator cap. Change the thermostat. These suggestions don't have me feeling optimistic.
On the bright side, I now might be able easily to find my exhaust leak! Smoke was also coming from rear of engine and blowing downward, I think the leak is in the y-pipe.
