fusion1620
SHO DWN
I did a transmission swap on a 95 non sho taurus to sell. The proceeds will be going towards my First GEN SHO which needs a lot of work. So if someone has had this problem b4 please help. The 95 is going through the check engine tests even when the pins are not jumped with the paper clip method from Shophoenix web site. So every time I start her up the idle is jumping up. She also doesn't want to start sometimes?? Just got done reading the codes and all I got was 538 the one for the goose test...Thanks
