slight vibration....???
xpnsiv93
Corrupt state, IL
I noticed on my way to Walgreen's (to pick up pics of The Goblin) that whenever i hit 3K rpm theres a slight vibration throughout the car :eek: what could that be...remember i just did a complete 60K, so i was thinkin crank bolt backin out?....also i noticed that i've got a bad pull to the right, been there before i have... :eek: :eek: could that b caused by low fluid(i have a leak down there)?? or something more serious?*prayin it's not*......and the car heats up quick...could that b caused by having NO cats???...thanx to all...sorry for SOOO many ?'s but if anyone knows these cars it's all of U!!!!!!
-nick-
marvsho17
Joshua S.
rockford, il
I'd immediately check out the crank bolt. You may have an air bubble in you cooling system. Whenever I drain and refill the radiator I let the car run w/o the radiator cap on and squeeze the upper rad hose. This has cured the running hot situation for me 2 times.
