Should there be holes in my air box?
mapicco
cleveland
I posted earlier about this and haven't got an answer to the thing I'm most worried about. It appears (doesn't look factory) as if someone drilled 2 holes in the bottom front of my intake, they are about an inch or two in diameter. Are these stock? Or could this be why my car drives much better with the MAF unglugged? If so what is the best way to go about fixing it (patch the holes or new). I'm begining to wonder if anyone has a stock intake around here to compare? I've had the car for a few years and its always been a dog but I haven't even noticed these holes before now.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
mine doesnt have any holes...I believe holes in the air box would bring hot air into the engine and therefore "slow" down the engine. aka not create as much HP...not a huge difference in HP I wouldnt think...
I wouldnt think that it would have almost any affect as to why your car runs better with the MAF unplugged.... :shrug:
inverse1216
daytona beach, fl
i doubt there should be holes in the box mine doesnt ahve any and if it looks like it shouldnt be there then they prolly shouldnt be heres soem pic of my stock air box i have a 93 mtx so idk if urs will look the same.
40BelowSummer
Puerto Rico
the airbox on my atx had holes as well, i think some ******* *** PO thought it would make it faster as is probably the case with yours. You can temp put duct tape over the holes
