SHOBros. Stage II Brake Kit
rcsavage
Florida
what size rotors are in this kit? 11.6?
http://www.shobrosgarage.com/product_info.php?products_id=198{21}160
K-Dawg
Treasure Coast, FL
That kit uses the 94/95 10.9" rotors.
You can get Mach 1 calipers for about $200 shipped and 11.6" rotors for $50 or whatever and it will be a much better brake upgrade.
Bda01SVTL
Riverside
You will need 94/95 knuckles and modified Mach 1 brackets also. seanMC has a set of NEW Mach 1 calipers and modified brackets i believe, and i have 11.6" rotors.
rcsavage
Florida
would i be better off buying the SHOBros. Stage III Brake Upgrade with the 12 inch option? (i cant afford new rims and i like the slicers) basically my knuckles now are garbage as well as wheel bearings and rotors and pads. i figure i might upgrade if it will cost close to the same, but im looking for the best vs cost efficient way to do it.
K-Dawg
Treasure Coast, FL
Bang for the buck:
Junkyard 94/95 knuckles - less than $100
New hubs/bearings in the knuckles - less than $100 with labor
Mach 1 Calipers from stangsuspension.com - $185 + shipping
Cheapest 11.6" rotors you can find - $45
And maybe some assorted hardware if you need it
Follow instructions that are stickied in the Suspension Mods forum and you're out the door for about $450 with everything.
sho_bc
Dragonboater
Vancouver, Canada
if you go that route, you'll need some 3-5mm spacers in order for the slicers to clear the calipers. I've got 5mm spacers, but could probably go down to 4mm if i wanted.
Bda01SVTL
Riverside
Bang for the buck:
Your going to need to machine the caliper brackets to make this work....
