That kit uses the 94/95 10.9" rotors.
You can get Mach 1 calipers for about $200 shipped and 11.6" rotors for $50 or whatever and it will be a much better brake upgrade.
would i be better off buying the SHOBros. Stage III Brake Upgrade with the 12 inch option? (i cant afford new rims and i like the slicers) basically my knuckles now are garbage as well as wheel bearings and rotors and pads. i figure i might upgrade if it will cost close to the same, but im looking for the best vs cost efficient way to do it.
Bang for the buck:
Junkyard 94/95 knuckles - less than $100
New hubs/bearings in the knuckles - less than $100 with labor
Mach 1 Calipers from stangsuspension.com - $185 + shipping
Cheapest 11.6" rotors you can find - $45
And maybe some assorted hardware if you need it
Follow instructions that are stickied in the Suspension Mods forum and you're out the door for about $450 with everything.
Yep.Your going to need to machine the caliper brackets to make this work....
