shojuan
You beat me to it Lance, while I was typing mine. And you said it better! thumbs_u
Lance Cheney:
Mike,
I think the things that would normally be interesting about this kit vs. the normal 96 upgrade are:
(A) better pedal feel and modulation due to the fixed-caliper 4-*** design design
(B) Higher clamping force due to higher piston area (this is somewhat equivalent to better stopping capability when the brakes become the limiting factor, vs. the tires)
(C) Less problems with brake fluid overheating, especially with the alternative piston materials available.
(D) Less unsprung weight. Yes, it doesn't seem like a lot, but it is a difference (moreso than saving 4-5 pounds on fog lamps).
(E) No worry about dust boots burning off, at least with the NDLs. My dust boots were gone after my first track day anyway, and the factory calipers don't have SS pistons.
I'm not ready to drop $1500 for the full kit but spending $500 to have calipers that are relatively worry-free and have additional advantages as above might be worth it. Many of the other advantages are things that I have had no personal experience with, so I have a hard time understanding just how useful they are on a car that is only run at the track 4 or 5 times a year.
The other thing is that stopping distance is generally referencing a cold pad, cold rotor situation. You might see some decent gains at higher temps, where brake compound friction starts to disappear, due to the higher clamping force. (if you ran at those temps very often, then dedicated race pads should be on your purchase list, however)
Pad options are actually pretty diverse for the '96+ upgrade. I have no problems with the Carbotech pads I've been using (P+ and XP) even at Laguna Seca. Like I said, the dust boots are vaporized.
Todd will likely have more things to say on this.
-Lance
