I would definitely plan on doing the TSS/OSS sensors and the solenoid body filter sooner than later, as a preventive measure. 4 hours of work, easily within your skillset, and under $200 in parts. Do at least 2-3 more drain and fills, spacing them out, as you gauge the transmission's response to the fluid changes.
Do you have any sort of a walk through, diagram, or write up that shows where this is all at and how to do it properly? I'm not opposed to spending a few more dollars at this point if I end up keeping it. Like I said before, I haven't done anything half way by trying to cut corners.
That being said, I still feel like the front passenger suspension is not right. Some bumps in the road make it still sound like something is loose. Between swapping all of the old parts for new and having the 4 wheel alignment done again last week for the 2nd time, I have no clue what could be loose. It's real disheartening after so much money and time went in to fixing it. This is the same problem that I started with when I first bought the car. Another reason for thinking of throwing in the towel for a different car and seeking a realistic value.
I am glad this has turned into a good discussion all the way around though!
Sent from my iPhone using Tapatalk Pro
