SHO clutch
audia65spd
connecticut
On the new SHO plus we just got the the pedal catches on the higher side of the pedal travel...but the clutch is almost brand new less then 8000 miles on it...and we have all the recipts to prove it(the age of the clutch) it is a spec stage 1 and spec flywheel...but we don't kno what to make of it..any thoughts would be apperciated
1993MTXSHO
Its a Taurus...
Jersey
iv got a spec stage 2 I jsut put in liek 2k miles ago and it catches on the higher side, if your is really bad jsut adjust it. Put the car in 1st gear pull up on the clutch pedle and your feel it click in then push down and if it needed adjusting it will click. Its all automatic if you didnt knwo that already:thumb:
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
if its brand new it has to catch at higher side, cause if it catches low youre do for a cutch cable adjustment
( recomended every 5000 miles or/8000 kilometers).. good luck with the new car man
