Sho Bros oversized radiator ?
AREA 91
PA SHO SHOP
Area 91
The ATX has less room between the rad support and engine than an MTX. That's part of the problem. The second problem may be where your sub frame is located in relation to the body. If the sub frame is slightly shifted towards the front of the car, you will have even less room.
Hopefully a ********* ATX'er will chime in.
