SHO being Screwy!!
ryancutler
Somerset, WI
Well, I was having a great day, got out of work early, and went out to my car...
Get in and try to start it, nothing...I had no f'n clue what was up...Lights weren't left on or anything... Noticed that the check engine light would flash and i could hear clicking under the hood (i wasn't turning the key when this would happen)...So I went to see if it wasn't in park all the way...I noticed I don't need the brake to take it out of park with the key turned forward...Once and a while all of the lights would come on, but by then the battery was dead...Anyone have any ideas?? I need my car back on the road ASAP!!
Ryan
[email protected]
[1992 Silver MTX]
IRT Performance Clutch, Dynomax Exhaust, Lund Tail light Covers, Coneless, K&N
[In Closet]- 17x7 Konig Caffeines, NOS #5120, red neons, red wheel lights, blazer techs, side marker lamps
[Next]- Rebuilt 3.2 with Ported & Polished Heads, Raised Compression, Stage II Cams, Adjustable Cam Sprockets, Stage IV IPT Clutch, 3 Angle Valves, Upgraded Valve Springs, IPT Coil Overs, Guages (A/F, Oil Pressure, Temp), IPT LSD, Nitto 450's 225-50-17, and PP y-pipe
[1993 Green ATX] -4 SALE-
Coneless, 73mm MAF, K&N, Superchip, DynoMax Pipes w/ [Glasspacks (Click 2 See Video)] -- [Another Video], 68mm TB, Removed A/C Compressor, Filled Body Molding (Gold), White Faced Guages, ACCEL Super Stock Wires, Powdercoated & Polished Intake
jthomas68
Area 51
Bad cable connections.Clean both connections at the battery,the starter selenoid,and starter.Mine did the same thing recently,but i doubt you have the same problem.My fan thermostat(aftermarket) didn`t shut it off for some reason,and the very low powered fan was barely spinning.
Jeremy Thomas
Juiced 91+
SHO Pic Of The Week:
T
ThatSHOkid
Guest
i agree. check your battery connections and cables. my car dies on my 3 times each right after it had been running. the first 2 were because the conenctions needed to be cleaned and replaced the third time it was my starter.
1993 White/Tan SHO MTX 97k Miles
[*] Performance: Sho Shop Y Pipe * Coneless & Boxless * K&N Filtercharger * Superchip Performance Chip
[*] Appearance: Colgan Custom Bra * "SHO" Windshield Banner * Blacked Out "SHO" Lettering * Ventshade Sunroof Wind Deflector & Vent Guards * GTS Headlight Blackouts
[*] Audio: Sony 10 Disc Changer
[*] Lighting: Eagle Super White Headlights * American Products Company Super White Reverse & License Plate Lights * Blazertech Foglights
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Sway Bars, Front Strut Tower Braces, & A Sig Pic!
[*] The Driver: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] The AIM Screename: KingPin641 (a NESHOC member)
"Drive it like you stole it!"
T
ThatSHOkid
Guest
