Shims?
89SHONOFF
Columbus,Ohio
In the latest cinci sho email newsletter it says ford is discontinueing vavle shims,Is this bad?
1989 SHO Lt.Titanium
K&N Filter
Msw Wheels
Hopefully More Soon!
1968 Buick Skylark W/455 Stage 1
70 Ford Torinow/302 and 60k miles.
Stock up now!
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
Shoman594
Moderator
Lockport, IL
Rob94
Northbridge MA
I will never understand why auto makers discontinue parts on vehicles no longer in production, but still found on the road in volume. There are still what, many numerous thousands of SHO's out there.......yet they discontinue a vital component needed to maintain these vehicles. Does a lot for consumer confidence in my opinion.
Rob
White 94MTX
K&N Filter otherwise stock
9
94ShoOff
Guest
Oh great, I can't wait to see what shims pull in on E-bay in a few years.
ArrestMeRedSHO
S. Windsor, CT
I may be a little out of the loop but isn't this a fairly simple part that we could have a job shop make if we needed in quantity or couldn't find a substitute?
1993 MTX Red w/black int
SHO Shop Y-pipe and Flex pipe
Dynomax Catback
Underdrive Pulleys
80mm MAF
LPM
"Fishtank Lights"
CincySHO Floormats
Yokohama Avids 215/60/R16
olympic
Saskatchewan, Canada
Somebody posted a while back that SHO shims are the same as the ones used in Yamaha motorcycles. I wouldn't get too worried, some aftermarket supplier will step up to fill the void.
SnoSho
Circle Pines, MN, USA
Rob94, WHy would ford stop making parts and send crate motors to scrap, CONSUMERS. THe whole point is to get us out of our 10 YO Taurus and into a new SES or whatever BS the dealers a passing out now on the SHO's slot in the line up. As for the Shims, I know the zx11 had a plug wrench that worked great on the SHO not sure about the shims.
TIm M.
TwiceSHOwn
Atlanta, Ga
SHIMs are the same for the motorcycles..not sure of price but Yamaha made them still as of 2 years ago.
93 Silver ATX 57K
LPM
80MM MAF
Y Pipe
Eibach + Tokikos
Front and Rear STBs
Cold air snorkel
TCE SHO stopper brakes
Recovering from its 60K...sigh
fredhurderjr
www.neshospecialists.com
Yamaha is under contract to make these engine parts for x number of years... I'm fairly sure the number was 17. That means, it should be 2005/2006 before engine parts are discontinued. I don't know about you, but I think this qualifies as an engine part.
I would stock up - I"m sure Josh T. is!
tsho2
Toyota is using Yamaha engines in some models, as well. I don't know if the shims are the same diameter though.
Could this just be a rumour?
fredhurderjr
I work in a stamping house. You tell me the material, give me dimensions, and I'll propose to the company that they start producing these. I'll need the range of thicknesses required as well, and if these things are plated, etc.
In quantity, these things shouldn't cost NEAR what Ford wants.
If someone wants to send me one (or two, if intake / exhaust are different somehow), send me an email & I'll give you the mailing address. Thanks!
philw349
PhilW
Tucson, AZ
What are Shims exactly? Are they a tool for the 60k, or a part on the car? I always hear of shops wanting their shims back though. Didn't see it in the glossary.
[This message has been edited by philw349 (edited 11-25-2001).]
In the picture below, the shim is the round, 2.5mm (approx.) thick metal disc that is installed on the top of the tappet, immediately under the camshaft lobe (upwards in this photo). You can see the thickness of the shim in the small notch in the tappet. The notch is to allow you to pop the shim out of the tappet to replace it during a valve gap adjustment. There is a required 0.30mm (0.25-0.35mm) gap between the camshaft lobe and the shim during the portion of camshaft rotation when the valve is closed.
Scott
[This message has been edited by sdpatt (edited 11-25-2001).]
