Shifter question
Ganday B
Norton, MA
Guys,
The front rod of my shifter that comes out of the black plastic box is very loose. I can move it all around the outlet of the box. Can someone tell me if this is normal or should there be a bushing or something? Putting the car in first is hard every once in a while.
Thanks
ckinart
Mississauga, Ontario
Ganday,
Inside that "black box" is a nylon ball and socket bushing. You can get a replacement set from SHOnut (look under the "Performance" section for "Rod Shifter Ball AND Socket Bushing". A relatively straightforward replacement. If you'd like, you can search the forum for some more info if needed.
Hope this helps!
