Zap
Greetings... I will be soon reinstalling my subframe during a clutch job, and was curious if anyone could help me out with these problems that I have not encountered before.
1. I will be installing new Al SFBs, and on one of the front old bushings, the ring with the nuts rusted so badly that it fell apart, leaving the nuts/bolts permanently spinning in the holes. How can I easily remove those nuts so I can install the new bushing? (FWIW, the nuts have small pieces of metal still attached to them on the bottom and the nuts came off slightly before the ring pieces just started spinning.
2. I believe that the tabs have failed on 3 of the 4 plate nuts. I know that I should have no trouble accessing the recall holes on the one rear nut, but both front nuts failed and will be replaced with new ones. What is the easiest way to raise the subframe and get it lined up properly?
3. I asked in the other forum, but I figure I could see if I get any additional input here. Since I have the SF off and everything apart, are there any inexpensive parts/bushings I should replace or grease to keep things operating smoothly? I don't want squeeks or other problems when I complete the major amount of service I'm doing to the car. Any suggestions are appreciated, as I am not as keen with the suspension related things.
Thanks!
Thanks!
