Sensors
Fine89
Pottstown, PA
Things like TPS, IAB, O2 sensors, do you guys replace these as maintenance items and when?
Is there any way to test injectors?
Thanks
Mr Anonymous
Tire Wall
Use the forum's search function for the topic '60K', as well as the forum's FAQ pages and you will find an abundance of information! :)
Of the sensors you mentioned, I would repalce the oxygen sensors at the same intervals as the spark plugs, or 60,000 miles, and service the others only if they cause EEC error codes or obvious driveability problems. As mentioned, a search of the Forum's archives will provide a large amount of the symptoms of these symptoms.
I recommend the Bosch 13942 sensors from AutoZone for $38.99.
rlw001
Reading, PA, USA
sdpatt:
Thanks Scott!
I just installed a set of 13942's. Gas mileage is better as is repsonse and drivability.
