SHOracer14
Me-0 Diffs-6
Well, I decided to run both KOEO and KOER self tests today to see if it would throw any new codes and help me figure out why this 93' is a slug. This is what came up but, have a few questions on some of them.
114- ACT out of self test range... I'm assuming I should just get another one but not too worried about it.
173- HEGO sensor indicates system rich (RH)... I'm lost one this one, I'm guessing RH means right head meaning front bank is rich... not too sure why though
219- SPOUT signal defaulted 10 degrees BTDC/SPOUT circuit open
213- SPOUT circuit open... I figured these two meant that the SPOUT was not there so I checked and it was. I then tried two other SPOUTS off of two good running cars with no change. I can't see any wires open or bad. Could there be a cut wire somewhere? Is there a ground or something for this? Or could this mean that the CID is bad?
225- knock sensor not sensed during diagnostic response test... I'm guessing that this is no problem as the knock sensor won't work unless there is detonation and I don't hear any pinging
All answers are much appreciated thank you!
rangerj
