SHO_ROLLER
How do you keep your Yamaha clean? Is it safe to use water and Castrol cleaner? Any advice would be helpful. Thanks!
Anthony shrug headbang
The engine compartment.SHO_ROLLER:
Is there anything I should cover up before I use a hose?
Anthony
I totally disagree... but I have already expressed my opinion. In 6 years of doing this on every motor I have ever cleaned, I have never had a problem.sdpatt:
Safe is not using water.
Scott, maybe you should start a class action case against all the manufacturers of spray on, hose off engine degreasers. Oh yeah, you would never be able to make a case that would get anywhere in court.sdpatt:
