Sho roller,
If you driving it on the street as an every day driver, SDPATT's advice is top drawer.
The SHO Times web site has a complete discussion about brake upgrades. You can upgrade your 1990 to 1996 standards if you want to change some suspension parts as well as brake disks, bearings, and pads. (Lincoln size)
This upgrade will give you larger brake disks and pads. The quality of disks and pads can be the same as above, but a little bigger.
If you are doing all out road-course racing then look into Bear brake products, and take out a home equity loan.
As long as your in the mood to improve your brakes, get a top quality brake fluid, such as ATE blue or gold or Castrol GT LMA, and flush your brake system. These are top quality dot 4 fluids that will take high heat, and are both Low Moisture Activity (LMA) fluids.
There are several other high performance brake fluids available, including one available thru Ford. The all out racing type can be as much as $70 a pint! (See the SHO Times web site re. brakes and brake fluids)
Well, you asked for some ideas, I hope this helps. rangerj
