roof removal and A pillar, and door lock motor
Blanik_SHO
Montreal,Canada
So this week end I will try to repair my sunroof problem that a lot of people got. the sunroof stop working and the windows so i unplug my sunroof switch and everything got ok....
but now i have to get my sunroof open for the warm season:thumb:
so i need advice to remove the roof near the panel switch in direction of passanger side and the passanger A pillar cover. I just ask because i don't want to break anything
i'll give you hint after :cool: ........thank
P.S. i'll also change my door lock motor by the same time......does someone alrady change this, since the motor in the door is "fix" in plac with a rivet, do we have to drill it first??? and put a metal screw after that??
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I can tell you the rear will pop out of that bracket, without removing the rivet. Just get a small flat screwdriver, and it'll pop out of that bracket. Now the other end can be fun, I think with the right pair of plyers you could get it out, but I'm going to take out the locking mechanism all together to get the thing out. I screwed my doorpanel back on and forgot about it, was doing my brakes at that time, and had other problems to attend to. Just havent finished it.
Blanik_SHO
Montreal,Canada
thank for the lock motor, i'll try with a screwdriver first if it don't work i'll just drill the rivet and put a bolt and nut after that.
for the roof and pillar? any help, i'm sure it's only clip, but some people have advice???
