Rod bearing wear question
SVOFANATIC
Matthews, NC
What is it that causes the rod bearings in cyl 4 to wear so much faster than the other bearings? On both the engines Ive pulled bearings from cyl 4's bearings were far far worse. I was under the impression that cyl 1 should be the most worn since it is the most unsupported and farthest from the tranny. Can anyone explain to me why this is?
usually, its #5 or #2, in all the engines and photos I've seen, that is the worst. it has to do with the oil flow path through the crank and also the bearing clearances on the various bearings, imho.
frosho
WOLFMAN
Tyngsboro, MA
IIRC, Ernie's oil starvation issues were always with #5 in his salt flats car.
SVOFANATIC
Matthews, NC
Maybe I have my cyls mixed up then. Rear bank crank side is #1 then front bank is 2, rear bank odd # cyls, front even #'s?
mavericksav
Moscow
I saw 3 time #1 cylinder (one of them was at ex-my 92 SHO). All time the problem was the dirt in oil magistral (line)
mavericksav
Moscow
I think there isn't any regularity in this problem
Ford's system of numbering cylinders is consistent throughout the line - the cylinder furthest from the flywheel is #1, and then it increases as you go down that bank. Then the other bank is numbered starting again on the end furthest from the flywheel.
That is how the V6 are 123 down the right bank and 456 down the left bank and the V8 are 1234 down the right bank and 5678 down the left bank.
