right rear caliper HELP!!
WhiteSHO625
il
can someone please help me my right rear caliper on my 91 SHO keeps going bad
and dragging i replaced it with a new one 2 weeks ago and its dragging already
do i just have bad luck with calipers or is there something wrong with my car that is making it go bad??
frosho
WOLFMAN
Tyngsboro, MA
If the rubber line leading to the caliper is original, I would replace that (do both sides). They can fail internally and prevent fluid from back-flowing out of the caliper when you release the brake pedal. The bracket bolted to the strut can rust and pinch the line off too.
tompumped
VT
There's a thread I started on here I think. I had the same problem and I thought it was the cables. Look at the spring for the e brake and see how big it is or photograph it. They had a large and small spring, when I got two calipers with the large spring I had no issues.
Also the bendix brake cables are the best by far. It seems all the others the right rear would drag slightly after using it for a little while. I tried like three different brands and all of them internally seemed to bind.
I'd replace the brake hoses either way if it's unknown how old they are. The last set I replaced were pinched bad.
