riddle me this
shonuffmine
wildchild
sweating balls in fla.pan
:woo-hoo::woo-hoo:i,m workin on my buddys 93 atx,got a code 113 n 157 act n maf volt low,changed the fuel filter,was really clogged up.the car idles decent now but when you whack it it bogs n will not rev over 4000.the secondarys are opening but derd on top n is a dog on gas.the the back plugs were badly fouled(6 was toast n was loose),i changed the tps n DIS,( are mtx n atx the same?) any idea guys ??? also checked n cleaned the grounds n they look good,when i left the bolts off my 90 mtx this how it ran too help pleaase :thankyou:
shonuffmine
wildchild
good possibilty,its pretty quiet for having a broken expansion joint on the exhaust, no funny whoosing sounds usually associated with a clogged cat although, but there is a is a funny sorta whistle like a vac leak n we both have looked hi n low for it thanks for the ideal, the more i think about it the more sense that makes
shonuffmine
wildchild
ok guys it purrs like a kitten now,new plugs n cleaned the MAF,then said heck with it we had one that was in better shape so just swapped em out,revs n pulls fine all the way to 7200 rpm when ya get in to it,funny thing is if you are in park n rev it only goes to 4200 n sounds like its hittin a rev limiter,is this factory ?besides that my buddy is happy n says this is the best it has ever run, thanks for all the suggestions
Brett
SHOs before HOs
Minnesnowta
that's a factory limiter meant to keep you from destroying your torque converter.
