blackcurrant
It is the cause for much of the fluid to drain out of my '94 MTX...not the shift-shaft seal. Evidently someone put it bac in without the circlip or reused an old one...
It's easy enough to slide but i wasn't ready to slide it too far out. I guess i just don't know what i'm doing. Is there enough play in the CV joint to slide the spline end of the inboard halfshaft all the way out of the diff to replace the circlip?
Has anyone had the driveshaft bearing go bad? This is the 'pillow-block' mounted on the frame on the differntial side of the inboard CV joint. It is only found on the MTX SHO RH driveshaft.
