Originally posted by smokesho:
well, i would suggest getting a shop to do this cause you need to compress the springs to get them on the strut. also, you need to lower and raise the car alot and must be able to pry at the bottom of the strut to get it to pop out. i have had monroe sensitracs installed in the rear about three months ago.
You must install the spring compressor to allow you to remove the springs from the old struts. Keep the springs in the compressor's grip as you slip them on the new struts. No compression necessary.
I have used a 1.5 ton bottle jack placed between the spindle and the lower spring deck on the strut to slip the strut out of the spindle. It usually only takes finger pressure on the short jack handle to generate the necessary force to separate the strut from the spindle.
Scott
1991, 253K miles, glass hood, police grill, SVO shifter, Catz fogs,
