Okay, so I'm getting close to buying myself a Gen-II SHO. The passenger rear-door has some damage to it, a truck backed into it. So, if I were to find a rear-door off a regular Taurus, would I be able to replace it, or do I need a SHO specific door?
Also, how difficult is it to strip the guts out of the door? I figured, if I got a new door, I'd strip everything, get the new door repainted and have my new door on.
Would I just be able to find a door off a Taurus with powerwindows, get the door repainted and then put the SHO interior onto the door? I assume it wouldn't be TOO difficult to replace a door.
Whats involved with it anyway? Do I just ratchet the door hinges, unplug the harness and ta-da?
anyway, you drop the pin in, drop it down so the bottom lines up, BTW have someone help, be careful when you go to hit it in with the hammer, you will mess your door jam up, and put the codder pin in after door is in place, after that do the top, HELLA easier!!! I could not find anything on this when I did it. I haven't replaced the sho's, hope I don't need to anytime this millinia, so, find which ever pin/hinge is closest to the door keep open bushing, and attack that one first. Hope that helps!
to Jelloslug
