Replacement pads for wilwood TCE kit
Clean 93
PA
I have the wilwood TCe brake kit that allows you to use the stock slicer wheels........my question it what pads to order, as in size.......i belive that I will get a bp-10 pad but i am not sure what size to order......
PAracer
West Chester, PA
Well, which caliper do you have? Should be included with Todd's paperwork.
Where in PA are you? I spend time between Hershey and West Chester.
Todd TCE
Tempe, AZ
It's either an older BSL (cotter pin hole) or the later FSL/BSL6 with the big bridge bolt.
You can use either pad plate but it's easier to get the one that fit right than cut out the cotter pin section to fit the FSL for example.
There are many pad options;
Street: BP10 or BP20 or even T if you want very low dust (and response)
Drag/Autcross: Poly D
Track day: Poly B or H depending upon your needs
