Removing dash to replace Temp display
94SHOusmc
Woodbridge, VA
Anyone have a nice set of pictures or easy to follow instructions on how to remove the piece of dash so that I can replace my Temp display with the cracked buttons. I have a 94 atx sho. Pictures are prefered but any help is appreciated.
SHOMA
Springfield, MA
I dont have step by step instructions, or a write-up, but it is very simple:
The metal piece that is in front of your knees, on drivers side, has 4 allen botls holding it in, I believe it is a 4mm? Once that is off, you can then see the bottom 2 torx screws holding in the dash surround. From there, there are 2 more torx bits above the instrument cluster area that are the same size as below). Thats all that is required to pull the unit out, but be sure not to rip any of the wires, etc.. and carefully unplug them from the respective switches... The EATC unit then comes out with I believe the same torx bits you used to remove the surround. Good Luck, email me at [email protected] if you have any troubles!
Kevin
