I'm trying to get to my water pump and I tried to remove the left tensioner pulley (viewing from passenger side fender) and i ended up breaking a piece of the casing that holds the pulley, as well as part of the lower timing belt casing.
How do I remove these pulleys (both, i only started on one, broke something, and came here) without further damage? Am I missing something?
I read on the 60k website that there is two 5.5mm hex screws that you loosen before trying to remove the actual pulleys but I couldnt find the screws anywhere near the pulleys so I just tried to strong arm em off.
