Remove ATX Shifter
shojoe
NJ
My thumb button broke on me the other day, and im awaiting a used shifter. I got the center console apart as well as unclipped the OD wire from the tabs. What else needs to be done to loosen and remove the shifter? I thought it would just slide up but it seems to only turn left/right abit but not up. Thank you for any help. :hail:
white93atx
pa
If you are trying to get the whole shifter out there are 4 bolts holding it down. There is a u shaped clip about half way down on the front.Pull that out to take of just the top.
yzstud
< my kawi
Minnesnowta
along with the vacuum lines that go to the shifter that releases the park brake when you switch gears out of park
shojoe
NJ
Thanks for the help. I got the 4 bolts undone, and the whole shifter loose, but cannot find the "U" clip you speak of. I did manage to get the shifter assembly loose, but it seems im taking way too much apart. I just need get the handle off. I turns a little bit ( about a 1/4" each direction), but will not slide up.
shojoe
NJ
Wow, blind me found the clip. I was looking in front of the whole assembly for it, lol.
shojoe
NJ
Yep, thats exactly what i'm doing. Just post that you're looking for a handle in the Want/Buy section.
