SHOnOFF
I have a question about the use of a remote starter on the SHO. I just installed one on my ATX a couple weeks ago and it works great. (It has the hood pin switch, brake connection, and everything else so that if you pop the hood, hit the brake, or try to shift out of park, it will shut off automatically.) Anyway, when it starts up, it turns on the parking lights to show that it's running, but it doesn't turn on the radio or climate control. The ad for the starter says, "Never get into a cold car again." However, because of the electronic climate control, the inside of the car can't start warming up until I get outside, get into the car, and put the key in the igntion (to the Run position)...then it will turn on the climate control and radio (if it was left on when I last shut off the car). I'm guessing that if I had a manual/mechanical climate control (with the knobs set to heat), they would automatically come on when the car starts. But is there any way for me to get the electronic climate control to come on with the remote starter?? Anyone else out there with experience on remote starters that can offer any tips or advice?? I'd really appreciate it. Thanks.
