reinforced motor mounts,
jrock
Guest
wausau wisconsin
Whats the best way to go about this.. I;m not going to spend $100 for a mount when i can do it myself for next to nothing.. Anyone know about the extra bolts or urethane procedure.. or a welded bar.. I saw a pic of that from sho nut..
Cocoa,Florida
you can make solid mounts yourself for next to nothing if you know how to weld.you just have to weld two pieces of metal between the base of the mount and the top piece where it bolts to the engine,and you do this on each side of the mount.
NJSHO
Clean Your Shorts!
NJ
you my friend need to search, all the posts you have made so far have been covered many many times
Jarrod
OK SHO - now in TX!
Midland, TX
I'm surprised he's had to ask this question. Is this not the same guy who showed us all up in that Ultimate Stock Brakes thread? Aren't he and his father SHO gods?
crystizel
