reconnecting lighter power need some help..
turbot4
pa
ok, for the life of me...i had no luck putting the little wire on the back after inserting the housing into the tube....
the plug came off the back , and you have zero room to put it back on ..anybody have a clue on the proper way to do this?...
i tried for about an hour different way's, and i could not...what am i doing wrong?
It's been many years since I messed with one of these. Does it just slide over the plug? Can you crimp it a bit to make connection tighter?
turbot4
pa
no, the sleeeve for the lighter must be screwed in like a light bulb, but the little plug that connects to the back of the sleeve is impossible to put on once you screw the sleeve in ...i tried pulling the connector through and plugging it on before screwing the sleeve in , but that don't work either...they give absolutely no room to do this...
Izzmo
SHO Enthusiast
Kansas City, KS
I had to do this when I bought my car. It's rather easy if you take the right steps to do it.
Did you take the the shift control panel off and then the ashtray?
If you take the ashtray completely out, then it's a breeze to hook it back up. An OEM Door tool works great for this.
Izzmo
SHO Enthusiast
Kansas City, KS
I don't believe so.. but you start at the cup holder and then work your way back. They are all interconnected. Make sure not to pry to hard though or else your tabs will break (and the panels will become wobbly).
You could try a quick search on v8sho.com. They might have one.
turbot4
pa
i'll mess with it next week, back to work tommorow...thanks for the help..
Ict_Lx
Back in School!
Marietta, Ga
IIRC, you can take the ashtray out without taking off the entire bezel. Seems like it was just a matter of squeezing the ashtray towards the rear to get it to pull out. I'll try in the morning and report back.
turbot4
pa
well, lmk...either way it was a pita and i was ******** like crazy...i did remove the stereo, but it did not help..
You take the cupholder piece of the console out first. Then the ashtray part just slides out to the rear. That gives you the room you need to get in there to slide the wire on the tab.
turbot4
pa
am i missing something, my cupholer is in the arm rest...
Izzmo
SHO Enthusiast
Kansas City, KS
Everything connects together... you have to start with the cupholders or else you will break the tabs.
Open up your console, and you will see that the cubholders kind of sit on top of the console at the very font. If you use a OEM Door removal tool, you can use it as leverage to pry the piece up.
Let me know if you cannot figure it out and I will take some pictures.
Ict_Lx
Back in School!
Marietta, Ga
That's right! Sorry, I haven't messed with the lighter in awhile and got confused. To the OP: Hope you get it all taken care of.
Izzmo
SHO Enthusiast
Kansas City, KS
You have to take the shifter panel out.. don't forget that. (Everyone seems to skip that.. I broke off a tab the first time I pulled mine out)
turbot4
pa
oh man , i'm going to screw this up.....i'll take my time and mess with it on thrusday, not time till then..
turbot4
pa
that is a good pic....i'll be trying it this thursday....
hopefully i don't break anything... :)
Izzmo
SHO Enthusiast
Kansas City, KS
Just remember there are 3 pieces and the middle piece (that goes around the shifter) has 2 tabs on both sides.
BE GENTLE WITH IT!
