92ShoOff
I finally finished tearing down my two 3.0 cylinder heads and would like to get them cleaned up really well. The inside of the heads are stained with dark brown oil and have a little bit of grit and dirt in them. How would you guys recommend thoroughly cleaning the inside and outside of these heads? Are there any machine shops out there that have a bath that it's safe on aluminum? I'd also like to run my intake manifold through a bath too if possible to get rid of all the build-up inside of it.
Also, is it okay to take a fine wire brush and high-speed drill to the intake and exhaust valves? My intake valves are mainly the ones that need some cleaning because they have hardened carbon buildup on them. Any recommendations on cleaning those as well?
Thanks,
Andrew
Thanks,
Andrew
482 not 582(yet). that's what I get for not proof reading
