rebuildig mtx and have few questions.
fred79
pittsburgh
firt would a machine shp or tranny shop carry roll pins. also I wondered if it would be helpfull to put some kind of grease on the differential pins and any other parts that would be usefull. some thing like assembly ****.
also what is the suggested tranny fluid I am trying to find mobil 1 synthetic ATF if any thing else is better let me know.
TYSHO
Earth
They should, or you can try a hardware store. I prefer stainless steel roll pins. Can't remember the OEM size, but I used 3/16" pins and 4mm punch to drive them in and out.
masho95
got Zex?
Chicopee, MA
As far as using assembly ****, I wouldn't bother. It dissolves when oil hits it and will probably do the same with transmission fluid. There should be tranny fluid in that area so I doubt the extra grease is going to help anything. You could always install a Quaife, that way you don't have to worry about any differential pins. :D
