Rebuild questions.
RichieSHO34
genoneSHO
Philly
So as some of you may know I recently spun a bearing and am having trouble getting any offer for more the 400$ offers from scrappers on craigslist. Now for the questions...
1. (This may sound stupid) Can I put a new crank/rod/piston in without out pulling the motor
2. Would it just be easier to do a swap. The guy who was supposed to buy the car got over zealous and bought a "380" hp motor for $400 of some engine shop online and some coil overs and ran out of money so I am think of buying that from him even though I know the trans doesnt do well over 300hp
3.I cant get on pheniox SHO. is there any other source of a write up on an engine swap.
You guys have been a lot of help with my short SHO career and I couldn't thank you enough
thanks,
Richie
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
1. It would be much easier to swap the motor.
2. I doubt he has a 380hp motor unless it is boosted.
AREA 91
PA SHO SHOP
Area 91
thanks,
Richie
It's much easier to swap in a good running donor engine.
I have a couple.
I also have a completely rebuilt 3.0L with all new rings, gaskets, bearings, etc... for sale. It has 9 miles on the rebuild!!!!!
I also am able to do the swap for you.
contact me via P.M. if interested.
jayro
Auburn, In
x2 on the swap. It would probably cost more to rebuild your current motor than it would to just get a complete running engine and drop it in.
RichieSHO34
genoneSHO
Philly
I have a couple.
I sent you another pm
kevinspann
Don't take my advice.
Richmond VA
There's no write up on an engine swap as far as I know. It's just remove, replace. Wiring harnesses might be different between different years/engines, but that's about all I can think of. I've got a motor too, but I'm not all that close to you.
vortex2450
Buying Parts...
North Carolina
bump.. anything? also looking for a new motor close to 19403
Search is your best friend my man.
I did a swap and made a detailed thread where I asked most of the common questions:
3.2l swap log
also, another thread a made before the swap :
checklist
There are other threads detailing swaps, I swapped in a 3.2l because i t required only slight modification and I got an awesome deal on mine., I posted mine because they were easier to find :p
-Josh
