Rear suspension and brake upgrades
DeaconBlue
Cleveland, Ohio
If you happen to subscribe to the SHOtimes list on Topica, this will be a repeat for you, but I wanted to share this with the rest of the SHOforum.
First of all I want to thank AutoXSHO (John V.). I gave him a call on Friday to let him know that I was going to install the rear 11.6" brake upgrade along with the GM tubular control arms and H-brace this past weekend at the shop here at work. Not only was John V. very interested in seeing the mods, he ended up spending 6 hours helping me wrench on the car. Heck, I think he may have done more wrenching than me! I just wanted to thank John V. for this, he helped turn a two day project into a one day job. Really cool! Thanks again John V.
Anyway all I can say is wow! I had first installed the 11.6" front brake upgrade two years ago, then further upgraded the front to the 13" Cobra/Baer/PBR setup last Summer and modified the rear load proportioning valve this past Fall, so I already know what better brakes feel like in an SHO. The rear 11.6" rear brakes work wonderful and look
great behind the 5-spoke 17" rims. The brakes seem very well balanced now and can scrub speed off FAST without any surprises. No problems over heating these 11.6" vented rear rotors, compared to the stock 10.1"
solid rotors. I don't have any installation pictures, but you can check out Brain Harris's site where there are pictures of these same mods done to any other SHO, who's owner's name shall remain namesless
http://sho.kythri.net/
The only draw back to the 11.6" rear brake upgrade is an increase of unsprung weight of 11.0 lbs on each rear corner. That's a LOT of extra weight! Using the 10.9" front rotors from the '94-95 SHO and '96-02 SLO
Taurus models would have saved about 1.6 lbs per corner and could have been a better choice in that regard. But you may not be able to mount the OE caliper mounting bracket low enough on the '93-99 hub with this style of adapter bracket. The two bolt hole ears on the hub and OE '89-92 caliper mounting bracket would interfere with each other. You would have to rotate the position of the rear caliper in relationship to the hub, which would cause all kinds of problems with brake flex line and emergency cable lengths. So a 10.9" rear brake upgrade may not be a true bolt-on possibility. You could cut the bolt hole ears off the hub and weld a steel adapter to the hub, but then that would not be a DIY job.
The GM or the so-called "Grand Prix GTP" rear tubular trailing arms (or as GM calls them lateral links) are truly assume. They are GM p/n 10262699 and are $67.08 list price each. These steel tubular trailing
arms are OE on; Buick '97-02 Century, '98-02 Regal, Chevy '95-99 Lumina, '00-02 Impala and '95-02 Monte Carlo, Olds '98-02 Intrigue as well as the Pontiac '97-02 Grand Prix, if I am not mistaken. If you decide to try and find them at a local salvage yard, make sure you try to find rust free examples where the steel threads in alunimum turnbuckle block
can still move freely and the rubber bushings haven't been beaten to mush. Or hit up your local friendly GM parts department. I got mine at 25% off list price or $50.31 each. That's better than the $35 each that the salvage yards were quoting for an unknown condition part. With the installation kit from SHO Nut Performance consisting of machined steel insert sleeves (to work with a smaller diameter Ford bolts) and special sized washers, this is truly a bolt-on mod. I also installed Nook's H-brace reinforcing bracket in the center H-box uni-body attachment point. This is a must with any type of tubular rear trailing arms setup.
I can't really describe the change in both character, handling and ride that this mod has made. When the suspension upgrades (Koni's, Eibach's, poly strut rod bushings, etc..) were done last Spring by Eric at Rickety Engineering, I had the 4 degree TRW eccentric bushings p/n 13235A installed in both the forward and rear trailing arms. Although this allowed for both camber and toe alignment adjustments, it remove most of
the compliance in the rear suspension as well, since these eccentric bushings are made of very hard plastic. The car really acted badly on rough pavement and small sharp suspension inputs were greatly amplified into the cabin. In fact because the H-box is not perfectly centered in
the uni-body of my car (surprise!) the stock trailing arms on the drivers side were actually coming into contact with the H-box at some point in their movement though the travel arch. The GM tubular trailing arms are much stiffer and stronger than the Ford stamped units, but weight the same 2.8 lbs each. They are adjustable in length and have
rubber bushings at both ends. This also allows for both camber and toe adjustments. The rubber bushings are cylindrical in shape with only 3/16" thickness between the center and outer steel sleeves, but that seems to be enough. There are no know polyurethane replacement bushing for these tubular control arms.
The handling is much improved with very linear response and the isolation is actually greatly improved and the noise
level in reduced. It's almost like a completely different rear suspension is now under the car, one that's taken a few dance lessons to boot
Along with the H-brace the whole rear end of the car seems much stronger and more solid. It's almost like driving a BMW or Mercedes sedan with their famed multi-link rear suspension systems. The car has a heavier more solid feel, yet it remains surprising nimble. Very different and yet VERY satisfying. I have to admit that some of this change in feel may also have to due with the added unpsrung weight of the 11.6" rear brake upgrade. Something like a mass dampening effect. No matter, I really like the change in character.
The old girl has found some new, very smooth moves
95 MTX
with a few mods
1fastsho
Athens Ga
I can get two piece rotors made for the rear.
Shawn Pasley
Innovative Performance Technologies
770-725-4631
www.iptech.tv
92 SHO red/grey
3.2L(bored) Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal length Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/coil-over suspension, poly-bushings everywhere,26mm FRONT sway bar, 28mm REAR sway bar,rear strut tower brace, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 Toyo Proxes T1-S's on TSW VX-1's. 15 lbs of boost here I come!
DeaconBlue
Cleveland, Ohio
Are they bolt-on replacement rotors for the fronts of the '96-99 SHO? How much lighter are they vs. the 17.1 lbs for the stock units? Are they at least groved? Are they zinc chromate plated? How much? TIA.
95 MTX
with a few mods
1fastsho
Athens Ga
I don't know the details yet...I havent ordered a set yet. Shoot me a private e-mail
Shawn Pasley
770-725-4631
www.iptech.tv
92 SHO red/grey
noSHO
ohio is for hustlers
Now the real question is, did you let John V take you for a RIDE in the car??
I think I'm going to need that H-brace. Took left hand turn at 45mph yesterday (that will teach you how to drive REAL fast) and decided at that point I want more reinforcement before I bend something. Handling mods are SO underrated. The only thing better than going fast, is going fast while turning.
DeaconBlue
Cleveland, Ohio
No, John V. had to leave at about 6pm, and I finished up torquing all the bolts to spec and pulled the car off the rack at about 8:30pm. So not he didn't get a change to check out the new rear brakes or suspension setup, as of yet
95 MTX
with a few mods
AutoXSHO
Glenwood, MD USA
I think noSHO is referring to me taking him for a ride in my car and turning his neighborhood into an autocross course.
Dave - I don't have the balls (more like I don't have a wallet thick enough) to drive John's car like I drive mine
John V
RJ-92
Crappy NYS
If that's the case you are truely the man. I have e-mailed everone trying to find some of these. Baer, Alcon, Willwood, TCE. No one could get me some.Shawn, please keep us informed as to what's up with these.
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
dynomax cat-back w/1 superturbo & 1 ultra-flo muffler,
street/strip clutch,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs, 26mm RSB
In storage for the winter
noSHO
John V
LOL. Hey you're more than welcome to come use my neighborhood as a course whenever you want. I'll gladly ride along to give you directions, too. I've gotta get springs and struts so I can scare the shit out of one of my friends on that turn like you did to me.
Did you get the SFCs installed yet?
DeaconBlue
Cleveland, Ohio
Hey John V, there is always the road courses like Blackhawk, Mid-Ohio, or a curtain neighborhood over in Cleveland Hts
95 MTX
with a few mods
AutoXSHO
Glenwood, MD USA
No, they're still propped up in my living room.
I keep intending to have them installed, but I just haven't gotten around to it. Definitely before April 22nd, or whenever the first autocross this year is.
Dave - Don't forget the 26mm RSB, the '96 brakes, and the rear brake proportioning plugs, too. Those all help the scare factor.
As for the roadcourses, I think I will miss my RX-7's ability to pull 147MPH on the back straight of Nelson Ledges in the SHO. Have to wait until it's a bit more sorted
JV
noSHO
Right, right. I've got a 28mm RSB now, though. It goes pretty nice with the 24mm front one. Poly bushings and HD end links, too. It's a little unpredictable when pushed REALLY hard, but is VERY neutral otherwise. That 45mph turn I took had understeer for the first half, then the ass end kicked out. It was interesting to say the least, but I think I'd like a little more oversteer. I'm going to see what I can do as far as stiffening the rear up without swapping in a smaller front bar, but if I have to end up going with a 22 or 23mm front bar to get what I want, then so be it.
The 96 brakes are going on this summer, I can't stand the stock brakes. It's like stopping a train...
I don't know how I would possibly get the rear proportioning valve unless one of you made it for me. Either way, the brakes, springs, and struts are all in line as soon as I get back home from school for the summer.
94shoboy
south shore, mass, usa
autox:: sound like me, i have full length SFC behind my couch, my two boxes of konis in one corner of my kicten tucked behind a cabinet and IPT coil overs in a box behind a chair in the opposite corner of my kitchen. i need a big heated garage
NJshofear
Medford NJ
ook since no one else has asked, how much for the adapters to put the 96 upgrade in the rear???
AutoXSHO
Glenwood, MD USA
The other John would have to answer that, but I'm not sure he will without permission from the creators. I get the impression they were not interested in a flood of requests, especially since many would be people wanting them for the cosmetic benefit.
Without big (bigger than '96) front brakes it would not be a good idea.
John? Cost?
Jv
