intimdatr
Got Cams?
So i got done installing my new REAR sway bar endlinks (ingalls from SHOsource) and to go with them i put in new REAR Energy Sup. control arm bushings.
After doing so i got in here and took it out for spin only to discover the ride is something comparable to a dump truck. Its AWFUL.
Im wondering if i got the Sway bar endlinks tightened down to right or something?? Or is the ride just going to be that bad?
I would like to point out the setup is: Ingalls control arms, Ingalls end link, Energy Sup. control arm bushings, And one stock and poly sway bar bushing )got the wrong size so i didnt put the other in...) Moog Springs with 1/2 coil cut and new OE shocks.
So what do you think, did install something wrong/to tight, or is the ride just that stiff?
David.:thankyou:
David.:thankyou:
