Rear strut rod removal
zblackbeast
SHOtarded
Omaha, NE
After fighting with the bolts for a few hours... I finally got them off.. Now how the **** does the struts rod come out of the spindle and or frame.. and how the **** do i get it back in?!!?
jmpSHO
Massachusetts
Only if you want to, if you can't pry the spindle enough you may have to remove the stabilizer link but I can't remember it's been a lont time since I did one.
biker889
Quakertown PA
My passenger side i was able to pry. But after fighting for 45min on the driver side i just disconnected the control arms.
zblackbeast
SHOtarded
Omaha, NE
i ended up unbolting the lower sway bar nut and taking the lower bushing off.. i then pushed back on the knuckle until it came loose and just kept screwing with it till i wiggled it to the ground!! :)
zach44102
BIG TURBO
Georgia
i know how bad those things are blackbeast. tried to help. keep working on your sho its looking really nice. just whatever you do, do not remove your rocker panel.
