Jamoeba
My proportioning/bias value on the rear axle of my '94 is no good.
It must be ceased inside the block as hardly any brake fluid gets through to the passenger rear caliper. Thus caliper is providing no braking force on the RR rotor.
Called a local dealer, and they indicated the part was no longer available.
In a USA forum a few years ago, there was a link to a site that sold machined plugs that apparently overrode the problem, but with that said, the bias value was, with the plugs, taken out of play.
As the Bias Value relieves brake pressure on the rear wheels so that they do not lockup on hard braking, due to the weight transfer to the front, most members had indicated that they hadn't encountered any problems with braking having installed the plugs.
Any thoughts, or anyone know where Bias block can be bought??
Thanks...
Thanks...
