JRA2000TL
The Complainer
Dumb question....if you do the 96 brake upgrade, is that only for the fronts or does it include the rears also? Reason I ask is that today I've figured out my right rear caliper is sticking or hanging. I'm not sure if the car has the correct year specific parts on the rear since the PO did the 96 brake upgrade. The fronts have the FN74 brackets, so they are, in fact, 96.
After reading the required parts for the upgrade, it looks like he would have had to upgrade the hub assemblies in the front. I was debating on replacing these with the wheel bearings as I've had an odd card-in-spokes noise I can't track down in the front. It can be felt in the gas pedal too.
Either way, I will need a right rear caliper. In a fit of road rage today as someone pulled in front of me with no signal, I took off hard in the car and slammed on brakes. The car dove and rotated toward the left. My brother noticed a cloud of heat/smoke from the RR wheel. Problem diagnosed. Caliper looks to be about 72 bucks. I hope I don't need to do a 4 wheel brake flush...PITA.
Oh yeah....also, my ABS light is on and they don't work. Is this because of the upgrade?
