Mike Kopstain
Hey guys. I'm doing the 96+ upgrade on the front and I'm wondering if I can use my old front rotors, pads, and calipers on the rear? Has anyone done this or if not what have you done?
Yes, it's doable. There are several thing you need, depending on the year of your car. The Gen I's had vented rear rotors, so if you have a GenII, you need to get the rear caliper mounting brackets for a GenI. You'll also need calipers and longer slider pins from a GenI. The hub is smaller in the rear than the front, so you also need an insert to make the 96 rotor 'smaller' in the middle so that it'll center over the hub. You also need a 'adapter". The adapter attaches to the knuckle and the caliper mounting bracket attaches to the spacer. This is what pushes the caliper further away from the hub to make room for the larger rotor. Here are pictures.......Mikeys_Taurus:
Sure they will - this is essentially a 96 brake upgrade, but for the rear.SHO91MTX:
by the look of the pictures, 16" rims will not clear this upgrade. Is that true?
AutoXSHO:
Why would it make a difference? The location of the brake caliper in a disc system is set by the geometry and location of the suspension componenents.
The '96 upgrade is doable as Kurt said, I have installed one myself. Putting the factory front '94-'95 rotors and calipers on the rear will not work, however.
John Vitamvas
What was the deal with the hub centeric rings, and custom machined caliper mounting brackets?DeaconBlue:
What does it take to do the rear brake upgrade?
'90-93 stock rear calipers, pads and mounting brakets
'96-99 11.6" front rotors
hub centeric rings to fit 11.6" rotors on rear hub
custom caliper mounting bracket to hub adapters
John V.is correct, the smaller '94-95 10.9" front rotors will not work because of bracket mounting interferance problems. Also please note that this setup adds 11 lbs of unsprung weight to EACH rear corner of the '93-99 SHO's (not sure about the additional unsprung weight for the '90-92 SHO's).
This upgrade should only be done if you have upgrade your front brakes BEYOND the '96 11.6" setup to something like the Baer/PBR 12.0", 12.5" or 13.0" setup or the TCE SHO stopper 12.2" or 13.0" kits. If all you have is the '96 11.6" front upgrade (or stock for the Gen III), do NOT bother with trying to upgrade the rear brakes.
